[postgis-users] troubles configuring postgresql
Alessandro Ceccotti alessandro.ceccotti at netxcalibur.com
Fri Jun 13 02:55:31 PDT 2003
I'm using postgresql 7.2.3 and I've to recompile it with the instruction
"--with-java"
When I'm doing the configuration command, all seems to be good, but when
i launch make it gives me the following etrror messages.
Any ideas on how I can do to solve this problem?
Thanks,
Alessandro
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory
`/root/postgresql-7.2.3/src/interfaces/ecpg/preproc'
make[3]: Leaving directory `/root/postgresql-7.2.3/src/interfaces/ecpg'
make[3]: Entering directory
`/root/postgresql-7.2.3/src/interfaces/libpgeasy'
make[3]: Nothing to be done for `all'.
make[3]: Entering directory `/root/postgresql-7.2.3/src/interfaces/jdbc'
/root/apache-ant-1.5.3-1/bin//ant -buildfile ./build.xml all \
  -Dmajor=7 -Dminor=2 -Dfullversion=7.2.3 -Ddef_pgport=5432
Buildfile: ./build.xml
all:
prepare:
check_versions:
driver:
[available] DEPRECATED - <available> used to override an existing
property.
[available]   Build file should not reuse the same property name for
different values.
property.
different values.
property.
different values.
     [echo] Configured build for the JDBC2 Enterprise edition driver
compile:
    [javac] Compiling 53 source files to
/root/postgresql-7.2.3/src/interfaces/jdbc/build
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/xa/XAConnectio
nImpl.java:57: cannot resolve symbol
    [javac] symbol  : class RollbackException
    [javac] location: package transaction
    [javac] import javax.transaction.RollbackException;
    [javac]                          ^
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/jdbc2/ResultSe
t.java:60: org.postgresql.jdbc2.ResultSet should be declared abstract;
it does not define getURL(int) in org.postgresql.jdbc2.ResultSet
    [javac] public class ResultSet extends org.postgresql.ResultSet
implements java.sql.ResultSet
    [javac]        ^
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/jdbc2/Statemen
t.java:25: org.postgresql.jdbc2.Statement should be declared abstract;
it does not define getMoreResults(int) in org.postgresql.jdbc2.Statement
    [javac] public class Statement extends org.postgresql.Statement
implements java.sql.Statement
    [javac]        ^
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/jdbc2/Connecti
on.java:37: org.postgresql.jdbc2.Connection should be declared abstract;
it does not define setHoldability(int) in
   [javac] public class Connection extends org.postgresql.Connection
implements java.sql.Connection
    [javac]        ^
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/jdbc2/Database
MetaData.java:40: org.postgresql.jdbc2.DatabaseMetaData should be
declared abstract; it does not define supportsSavepoints() in
    [javac] public class DatabaseMetaData implements
java.sql.DatabaseMetaData
    [javac]        ^
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/jdbc2/Prepared
Statement.java:32: org.postgresql.jdbc2.PreparedStatement should be
declared abstract; it does not define setURL(int,java.net.URL) in
    [javac] public class PreparedStatement extends Statement implements
java.sql.PreparedStatement
    [javac]        ^
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/jdbc2/Callable
Statement.java:42: org.postgresql.jdbc2.CallableStatement should be
registerOutParameter(java.lang.String,int) in
    [javac] public class CallableStatement extends
implements java.sql.CallableStatement
    [javac]        ^
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/largeobject/PG
blob.java:26: org.postgresql.largeobject.PGblob should be declared
abstract; it does not define setBytes(long,byte[]) in
    [javac] public class PGblob implements java.sql.Blob
    [javac]        ^
    [javac]
clob.java:26: org.postgresql.largeobject.PGclob should be declared
abstract; it does not define setString(long,java.lang.String) in
    [javac] public class PGclob implements java.sql.Clob
    [javac]        ^
    [javac]
/root/postgresql-7.2.3/src/interfaces/jdbc/org/postgresql/xa/ClientConne
ction.java:70: org.postgresql.xa.ClientConnection should be declared
abstract; it does not define setHoldability(int) in
    [javac] final class ClientConnection
    [javac]       ^
    [javac] Note: Some input files use or override a deprecated API.
    [javac] Note: Recompile with -deprecation for details.
    [javac] 10 errors
BUILD FAILED
file:/root/postgresql-7.2.3/src/interfaces/jdbc/build.xml:72: Compile
failed; see the compiler error output for details.
Total time: 3 seconds
make[3]: *** [all] Error 1
make[3]: Leaving directory `/root/postgresql-7.2.3/src/interfaces/jdbc'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/root/postgresql-7.2.3/src/interfaces'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/root/postgresql-7.2.3/src'
make: *** [all] Error 2
Ing.Alessandro Ceccotti, netXcalibur s.r.l.
Via Alamanni, 25
I-50123 Firenze
T: +39.055.285859 - F: +39.055.285760
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030613/5510f296/attachment.html>
