[postgis-users] stat failed on file '$libdir/postgis.dll': No such file or directory
Obe, Regina DND\MIS robe.dnd at ci.boston.ma.us
Fri Jun 13 08:33:28 PDT 2003
Actually slight correction.  You have to use the unix path I think.
/lib
I think is what you want to replace it with if you have it in the lib
folder.
-----Original Message-----
From: Mike Leahy [mailto:mgleahy at fes.uwaterloo.ca]
Sent: Friday, June 13, 2003 11:26 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] stat failed on file '$libdir/postgis.dll': No such
file or directory
Hello all,
I've finally got the Cygwin version of PostgreSQL/PostGIS built - yay!.  I
used the DLLIMPORT command in cost.h, and ran "make clean" before trying the
build a second time (this was the small detail I was unaware of all along).
Now I've got another error that occurs when I try to run the postgis.sql
file after the createlang:
psql:postgis.sql:249: ERROR: stat failed on file '$libdir/postgis.dll': No
Yes, the DLL is in C:\cygwin\lib, but clearly there's something I'm missing.
I've got the PGLIB variable set in my environment settings (in WinXP)...but
that doesn't seem to matter in this case...
Any suggestions?
Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030613/1c330b38/attachment.html>
