[postgis-users] postgis and mapserver - queries
C F gis_consultant at hotmail.com
Fri Jun 13 13:51:44 PDT 2003
I think this discussion is probably dead and you've moved on with the
'explain verbose'.... but an interesting note if you're still interested...
As I said, I was doing something similar for my own version of a map server
and this looks like it may alleviate the problem of trying to execute a
query to see the result set structure (data types and column names) without
eating up much cpu time.  This *appears* to be a solution but I don't have a
large dataset handy to test it on or maybe someone can see a flaw in my
logic for other query types.
Basically it appears that PostgreSQL is smart enough to not to execute
subqueries when it knows the outer expression will always be false.  Here
are some samples...  notice in examples 3 & 4, the "never executed"
statements.
1)
postgres=# explain analyze select id from layer;
                                         QUERY PLAN
Seq Scan on layer  (cost=0.00..1.04 rows=4 width=4) (actual time=0.00..0.00
rows=4 loops=1)
Total runtime: 0.00 msec
2)
postgres=# explain analyze select * from (select id from layer) a limit 0;
                                            QUERY PLAN
Limit  (cost=0.00..0.00 rows=1 width=4) (actual time=0.00..0.00 rows=0
loops=1)
   ->  Seq Scan on layer  (cost=0.00..1.04 rows=4 width=4) (actual
time=0.00..0.00 rows=1 loops=1)
3)
postgres=# explain analyze select * from (select id from layer) a where 1 <
0;
                                    QUERY PLAN
Result  (cost=0.00..1.04 rows=4 width=4) (actual time=0.00..0.00 rows=0
loops=1)
   One-Time Filter: false
   ->  Seq Scan on layer  (cost=0.00..1.04 rows=4 width=4) (never executed)
Total runtime: 1.00 msec
4)
postgres=# explain analyze select * from (select id from layer group by id)
a where 1 < 0;
                                          QUERY PLAN
Result  (cost=1.08..1.10 rows=1 width=4) (actual time=0.00..0.00 rows=0
loops=1)
   ->  Subquery Scan a  (cost=1.08..1.10 rows=1 width=4) (never executed)
         ->  Group  (cost=1.08..1.10 rows=1 width=4) (never executed)
               ->  Sort  (cost=1.08..1.09 rows=4 width=4) (never executed)
                     Sort Key: id
(never executed)
>From: David Blasby <dblasby at refractions.net>
>Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Subject: [postgis-users] postgis and mapserver - queries
>Date: Mon, 09 Jun 2003 10:04:56 -0700
>I recently changed mappostgis.c so its a bit wiser about how it determines
>the columns in a query.  Previously, it did this:
>EXPLAIN VERBOSE <query>;
>The advantage of this is that it is extreamly quick.  Unfortunately, the
>EXPLAIN VERBOSE command changes its output with different versions of
>postgresql.  For example, in 7.1 and 7.2, the EXPLAIN VERBOSE is set as a
>NOTICE message.  In 7.3 its sent as a query result (and is formated
>differently).
>The new mappostgis.c determines columns like this (<query> is basically the
>query in your DATA statement):
>SELECT * FROM (<query>) as foo LIMIT 0;
>Basically, it executes the query asking for zero rows.  In most cases this
>will return a result (where you can determine the column names and types
>easily) quickly.  Unfortunately, i noticed that it can actually take a long
>time to execute.  For example, imagine you have a big table with road data
>in it:
>SELECT * FROM (  SELECT gid, sum(len) FROM roads GROUP BY gid) as foo LIMIT
>0;
>This can take many seconds to compute because postgresql will do the entire
>GROUP BY (which involves a SORT) before it can start returning results.
>I was thinking that you can use the fact you know the unique column
>attribute ("using unique <column>") and the geometry column's name to speed
>things up by reducing the query set:
>SELECT * FROM (<query>) as foo WHERE <unique column> = -666 AND
><geom_column> && 'BOX3D(0 0, 0 0)' LIMIT 0;
>[Here -666 and the BOX3D are just made up to reduce the query results]
>But this seems pretty hacky (and will not always work cut down on the work)
>- anyone else have ideas?
>dave
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
_________________________________________________________________
The new MSN 8: smart spam protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
