[postgis-users] stat failed on file '$libdir/postgis.dll': No such file or directory
cédric bernier cedric.bernier at thales-is.com
Wed Jun 18 00:53:08 PDT 2003
Hello,
I would like to unsuscribe, what shall I do ?
  ----- Original Message -----
  To: 'PostGIS Users Discussion'
  Sent: Friday, June 13, 2003 5:33 PM
  Subject: RE: [postgis-users] stat failed on file '$libdir/postgis.dll': No such file or directory
  Actually slight correction.  You have to use the unix path I think.
  /lib
  I think is what you want to replace it with if you have it in the lib folder.
    -----Original Message-----
    From: Mike Leahy [mailto:mgleahy at fes.uwaterloo.ca]
    Sent: Friday, June 13, 2003 11:26 AM
    To: postgis-users at postgis.refractions.net
    Subject: [postgis-users] stat failed on file '$libdir/postgis.dll': No such file or directory
    Hello all,
    I've finally got the Cygwin version of PostgreSQL/PostGIS built - yay!.  I used the DLLIMPORT command in cost.h, and ran "make clean" before trying the build a second time (this was the small detail I was unaware of all along).  Now I've got another error that occurs when I try to run the postgis.sql file after the createlang:
    psql:postgis.sql:249: ERROR: stat failed on file '$libdir/postgis.dll': No such file or directory
    Yes, the DLL is in C:\cygwin\lib, but clearly there's something I'm missing.  I've got the PGLIB variable set in my environment settings (in WinXP).but that doesn't seem to matter in this case.
    Any suggestions?
    Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030618/ddf31cee/attachment.html>
