[postgis-users] Re: shp2pgsql bug?
Ross Presser rpresser at Imtek.com
Wed Jun 18 08:57:58 PDT 2003
Paul Ramsey <pramsey at refractions.net> wrote in
news:3EA05259.8050502 at refractions.net:
> It'll have a different problem, but still will probably mess you up.
> An alternative loading path could be via OGR, assuming OGR handles
> large numbers gracefully.
Another workaround is to create the table yourself with the offending field
defined as a character field; then use shp2pgsql WITHOUT the -c option;
then convert the field back to numeric (using ALTER TABLE ADD COLUMN ...,
UPDATE ..., ALTER TABLE DROP COLUMN ...) after loading .  Had this myself
regarding the ID field in some TeleAtlas data.
Ross Presser -- rpresser AT imtek DOT com
"... VB is essentially the modern equivalent of vulgar Latin in 13th
Centurary Europe. Understand it, and you can travel to places you never
heard of and still understand some people." -- Alex K. Angelopoulos
