[postgis-users] Fw: Mapserver Query problems
David Blasby dblasby at refractions.net
Wed Jun 18 09:25:03 PDT 2003
>  Error
> executing POSTGIS SQL statement (in FETCH ALL): EXPLAIN VERBOSE SELECT *
> FROM (select * from mesure) as foo - Error with POSTGIS data variable.
You're most likely using postgresql 7.3 and need a more modern
mappostgis.c.  You can get it from the mapserver CVS archive.
dave
