[postgis-users] Postgis Transform Problem
Paul Ramsey pramsey at refractions.net
Wed Jun 25 06:24:51 PDT 2003
Those coordinates are right on the edge of the global plane, could be
hitting the edge of validity in the reprojection library. Try testing
the same stuff directly using the proj4 cs2cs utility.
On Tuesday, June 24, 2003, at 10:35 PM, Benjamin Wragg wrote:
> I'm having a problem with the transform function in Postgis. If I run
> the following query:
> select transform(GeometryFromText('MULTIPOLYGON(((112 -45 ,112 -10
> ,155 -10 ,155 -45,112 -45)))',4326),54004)
> I get:
> SRID=54004;MULTIPOLYGON(((12467782.9688466
> -5591295.91855339,12467782.9688466 -1111475.10285223,17254521.0729574
> -1111475.10285223,17254521.0729574 -5591295.91855339,12467782.9688466
> -5591295.91855339)))
> But if I do:
> select transform(GeometryFromText('MULTIPOLYGON(((-180 -90 ,-180 90
> ,180 90 ,180 -90,-180 -90)))',4326),54004)
> I get:
> Error: transform: couldn't project polygon
> Warning: Error occurred while executing PL/pgSQL function transform
> Warning: line 2 at return
> Any ideas why? I turned the postgresql log level to debug5 to see if I
> could get more detailed errors, but it's exactly the same error. I'm
> running postgresql 7.3.2, postgis 0.7.5 and proj 4.4.7
> Thanks,
> Benjamin Wragg
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
