[postgis-users] Installation problem on Linux
Hugh W. O'Brien hugho at intelis.com
Tue Mar 4 12:26:28 PST 2003
Beautimus P ! :-)
Thanks bud.
-- Hugh
Paul Ramsey wrote:
> You could search-and-replace the $libdir with the full path of the
> library. That would be functionally equivalent to the old style of paths.
> P.
> Hugh W. O'Brien wrote:
>> It seems I have been bitten by the bug that has ravaged some of the
>> Windows users of this list during installation.  I have a default
>> install on RH Linux 8.0.  When I run:
>> psql -f postgis.sql -d storelocator
>> I get the following error:
>> psql:postgis.sql:18: ERROR:  stat failed on file
>> '$libdir/libpostgis.so.0.7': No such file or directory
>> I am using the default PostgreSQL ( ver. 7.2.2-1 ) installation of RH
>> 8.0 ( I am using the src provided by the dist ) and PostGIS ver. 0.7.4
>> Any thoughts?
>> -- Hugh
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
