[postgis-users] Undefined references
Nicolas RIBOT nri at scot.cnes.fr
Tue Mar 25 06:59:24 PST 2003
Hello Marc-Andre,
Try replacing '$libdir/postgis.dll' by the full Windows path to
postgis.dll (something like c:\cygwin\urs\src...\postgis.dll) in your
postgis.sql file.
I'm not sure if system variables, like $libdir, are correctly handled
when running scripts.
I had many errors with this too on my cygwin installation: I was not
able to put as system variable in this script to point to the
postgis.dll folder.
It is also possible that you have to escape the '\' character.
(c:\\cygwin\\... for example).
I hope this helps.
Nicolas Ribot
> Paul,
> Thanks!  I have been able to install PostGIS!!!
> But now, I would like to buid a layer in PostGIS and view it
> from Mapserver...
> I have still created my DB and the createlang command worked
> correctly.
> However, here is what I get when I call the following command:
> $ psql -U postgres -d myGISdb -f postgis.sql
> BEGIN
>         message
>  PL/PgSQL is installed.
> (1 row)
> NOTICE:  ProcedureCreate: type histogram2d is not yet defined
> psql:postgis.sql:18: NOTICE:  ProcedureCreate: type
> ed
> ERROR:  stat failed on file '$libdir/postgis.dll': No such
> file or directory
> psql:postgis.sql:18: ERROR:  stat failed on file
> file or directory
> ERROR:  current transaction is aborted, queries ignored until
> end of transaction
>  block
