[postgis-users] Re: ./configure all over again?
Gregory S. Williamson gsw at globexplorer.com
Tue Nov 4 15:01:51 PST 2003
You need to run the make file within the contrib/postgis directory ... there is a README.postgis with instructions ... basically a "make" and then a "make install" to the last steps of setup. There's also some sql that needs to run in the appropriate database.
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From: Byron Amerson [mailto:byronea at u.washington.edu]
Sent: Tuesday, November 04, 2003 2:33 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Re: ./configure all over again?
I guess I need to be more specific.
First for my own clarity:  when we refer to the source tree, do we mean
the source I used to build said postgres?
I do indeed have a running version of postgres.  And in
/usr/local/src/postgres/Postgres7.4beta5 is where all of my source
material is (configure scripts etc).  In a directory there called contrib
I untarred postgis.  I then switch one directory up (back to
Postgres7.4beta5) and here I type:sudo make.  This is when make barks that
there is no target specified (or similar, I am writing from a location
remoteof my computer). Thus comes my question about running ./configure
again so that make has something to work with.
Forgive my elementary questions here, I am learning and I appreciate your
patience.  Thanks.
Byron Amerson
MS student
University of Washington
Department of Earth and Space Sciences
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
