[postgis-users] Create View with PostGis table
strk strk at keybit.net
Wed Nov 12 06:35:51 PST 2003
Try a newer (or older) mapserver, or ask in the mapserver-users
mailing list.  Returning a Server Error is a bad habit.
Read your HTTP server error message also, you might find additional
informations there.
--strk;
opengis wrote:
> Howdy,
> I need to CREATE VIEW of PostGis table.
> My landusea_region table:
> Field		Type
> gid 		int4
> polygon_id 	int8
> name 		varchar
> langcode 		varchar
> type 		varchar
> city 		varchar
> the_geom 		geometry
> Early I try with simple VIEW
> test=> CREATE VIEW only_pg_view AS SELECT *  FROM landusea_region;
> test=# \dv
>            List of relations
>  Schema |    Name         | Type |  Owner
>  public | only_pg_view | view | postgres
> (1 row)
> PostGres-PostGis work fine, but when I try to use this view in mapserver with mapfile like:
> LAYER
> 	NAME LandUseA_region
> #	DATA LandUseA_region # original shape file  -- work fine
> 	CONNECTIONTYPE postgis
> 	CONNECTION "user=pg_user password=pg_passwd dbname=test host=linux_box"
> #	DATA "the_geom from landusea_region"  # work fine
> 	DATA "the_geom from only_pg_land_use"  #    DOESN’T WORK!!
> 	STATUS ON
> 	TYPE POLYGON
> 	LABELITEM "name"
> 	LABELMAXSCALE 50000
> 	CLASS
> 		TEMPLATE "land.html"
> 		EXPRESSION ('[type]' = 'PARK (CITY/COUNTY)' )
> 		NAME 'Urban park'
> 		COLOR 0 210 0
> 		LABEL
> 			COLOR 25 120 50
> #			POSITION AUTO
> 		END
> 	END
> END
> I’ve this:
> Server error!
> The server encountered an internal error and was unable to complete your request.
> Error message:
> Premature end of script headers: mapserv
> If you think this is a server error, please contact the webmaster
> Error 500
> linux_box
> mar 11 nov 2003 17:31:31 CET
> Apache/2.0.40 (Red Hat Linux)
> I suppose need INSERT INTO geometry_columns table. I try to duplicate landusea_region record:
> f_table_schema f_table_name 	f_geometry_column coord_dimension srid	type 		attrelid varattnum
> test		 landusea_region  	the_geom  		2		-1	MULTIPOLYGON  17464   7
> in
>  test  only_pg_land_use  the_geom  2   -1   MULTIPOLYGON  17464   7
> but mapserver send me same Server error!
> Environment
> RH9
> Mapserver4
> Postgres 7.3.2
> PostGis 0.5
> Any suggest, sample?
> Best regards
> P.S.
> Why I need to CREATE VIEW?
> Because I’ve geo-data in PostGres-PostGis table and miscellaneous data in other tables (and other remote db).
> With a single VIEW I can map both of them.
> opengis (at) libero (dot) it
> AOL: open2gis
> postgis-users mailing list
pallamondo.net  <-- take a look !
