[postgis-users] spatial reference system questions
Steffen Koehler skoehler at buschjena.de
Wed Oct 8 07:01:23 PDT 2003
Hello,
I have installed postgis 0.8, proj 4.4.7 and mapserver 4.0
And I have data from germany with the following esri-prj description
PROJCS["Germany_Zone_3",GEOGCS["GCS_Deutsche_Hauptdreiecksnetz",DATUM["D_Deutsche_Hauptdreiecksnetz",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",3500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",9.0],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
I found this in the postgis spatial_ref_sys table as EPSG:31493. But in the
proj-files there is no EPSG:31493, I must use the ESRI:31493 entry to show
this data correct with mapserver.
Where is the mistake? Is the spatial_ref_sys-table false or the proj-files.
Can UMN-Mapserver use the entry from spatial_ref_sys for displaying data.
If this not so, how can I create dynamic maps with different layers from
postgis with the correct projection.
Thank
Steffen
