[postgis-users] Dissolve obsolete polygon borders
strk strk at keybit.net
Wed Oct 15 06:58:07 PDT 2003
Try this:
CREATE AGGREGATE unite (
        sfunc = GeomUnion,
        basetype = geometry,
        stype = geometry
); -- this creates an aggregate out of GEOS's geomunion()
-- and this is your query
SELECT your_attribute, unite(the_geom)
	FROM your_table
	GROUP BY your_attribute;
Note that GEOS cvs version is pretty memory absorbing (actually leaking)
and probably also buggy. Please let me know whether it worked for you.
--strk;
Horst.Duester wrote:
> Is there a way to dissolve obsolete borders between polygons with equal
> attributes??
> I will appreciate your hints.
> Horst
> postgis-users mailing list
