[postgis-users] FW: postgis.sql
Anthony Agoro (C) Anthony.Agoro at ordnancesurvey.co.uk
Wed Oct 15 09:30:07 PDT 2003
> Hi,
> I hope you can help. I installed Postgres7.3.4 and successfully created a database.
> I am trying to  load the PostGIS object and function definitions into my  database by loading the postgis.sql definitions file.
> logged on as postgres user using the folloing command
>   # psql -d [yourdatabase] -f postgis.sql
> I  get the following error:
> postgis.sql:  No such file or directory
> I did attempt to locate postgis.sql script but was unable to.
> Can any one help?
> Regards,
> Anthony
If you have received this email in error, please delete it immediately and notify the sender.
This email may contain confidential information and if you are not the intended recipient, you must not copy, distribute or rely on it.
As email is not a 100% secure communications medium, you accept that there are risks in communicating by email by doing so. We advise you to check that emails and attachments are virus-free before opening them. No contracts can be entered into on our behalf by email. Opinions expressed in this email are not necessarily endorsed by us unless otherwise specifically stated. We reserve the right to read and monitor any email or attachment entering or leaving our systems without prior notice.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 023 8079 2000
http://www.ordnancesurvey.co.uk
