[postgis-users] Dissolve obsolete polygon borders
strk strk at keybit.net
Thu Oct 16 00:20:44 PDT 2003
Horst.Duester wrote:
> strk
> Thank you for your response. I doesn't work, PostgreSQL responses with
> "GEOS union() threw an error!".
> Horst
Try downloading the latest postgis from CVS repository, it now contains
new code to show a more meaningful message (thanks Dave).
--strk;
> -----Ursprüngliche Nachricht-----
> Von: strk [mailto:strk at keybit.net]
> Gesendet am: Mittwoch, 15. Oktober 2003 14:58
> An: PostGIS Users Discussion
> Betreff: Re: [postgis-users] Dissolve obsolete polygon borders
> Try this:
> CREATE AGGREGATE unite (
>         sfunc = GeomUnion,
>         basetype = geometry,
>         stype = geometry
> ); -- this creates an aggregate out of GEOS's geomunion()
> -- and this is your query
> SELECT your_attribute, unite(the_geom)
> 	FROM your_table
> 	GROUP BY your_attribute;
> Note that GEOS cvs version is pretty memory absorbing (actually leaking)
> and probably also buggy. Please let me know whether it worked for you.
> --strk;
> > Is there a way to dissolve obsolete borders between polygons with equal
> > attributes??
> > I will appreciate your hints.
> > Horst
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
