[postgis-users] DISTANCE function doesn't work at 179,-179	degrees
    Paul Ramsey
    pramsey at refractions.net
    Wed Oct 22 09:20:23 PDT 2003
We do not handle lat/lon as if they are on a sphere, we do it as if they
are on a plane. Doing things in spherical is a PITA. Basically we would
need a whole separate mode for calculations which carefully dealt with
the singularity points in lat/lon.
P.
Andrew Edmondson wrote:
> I have two points either side of the 180 degree line on a sphere. (example included)
> Calling DISTANCE on them, doesn't yield the result 2, but rather 357...
> Have I not actually got a sphere?
> Or does DISTANCE not do what I expect?
> Thanks,
> -Ed
> <example>
> test=# SELECT * FROM location;;
>  location_id | latlong
>            1 |  SRID=4278;POINT(0 0)
>            2 |  SRID=4278;POINT(0 90)
>            3 |  SRID=4278;POINT(0 179)
>            4 |  SRID=4278;POINT(0 -179)
> (4 rows)
> test=# SELECT DISTANCE(latlong, GeometryFromText('POINT(0 178)',4278)) from location;
>      distance
>               178
>                88
>                 1
>               357
> (4 rows)
> </example>
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
