[postgis-users] Suspect shape(s) -- multipolygons and large loadfiles
Paul Ramsey pramsey at refractions.net
Tue Oct 28 07:59:06 PST 2003
Make us a shape file with just that geometry in it, and we might be
able to find out what is wrong (my money is on it being a completely
bogus deviation from the published standard :)
P.
On Tuesday, October 28, 2003, at 12:23 AM, Gregory S. Williamson wrote:
> I acquired the latest and greatest cvs version (as of about 16:00
> today, Pacific time) and tada! it correctly parsed my earlier
> troublesome multiploygon geometry. Thanks for the hint!
> However, in the "no good deed goes unpunished" category, I have
> another troublesome shape from the same table, a polygon (attached as
> a text file). It has 464 points; JUMP tells me it is a "self
> intersection" and returns it as an "L" shape.
> This is what the shape2pgsql generated:
> Insert into sid_content_cust2
> (gid,TRACKING_ID,P_DISK_ID,P_MACHINE,B_DISK_ID,B_MACHINE,STACKING_OR,P_
> DIRECTORY,B_DIRECTORY,FILENAME,PROJ_KEY,COPYRIGHT,the_geom)
> values('212528','111111','11','aserver','1','aserver','2227','/
> directory/','/
> directory','5m_st_tropez.sid','French_Lambert_II_Etendu','1',GeometryFr
> omText('MULTIPOLYGON()',4326) );
> This gets:
> psql:xab:30: ERROR:  couldnt parse objects in GEOMETRY
> (natch)
> This shape may violate some rule -- Informix seems to cope with it;
> JUMP doesn't; won't be able to try ARC stuff until tomorrow.
> Any (further) advice would be welcome !
> Thanks,
> Greg Williamson
> DBA
> GlobeXplorer LLC
> -----Original Message-----
> From:	strk [mailto:strk at keybit.net]
> Sent:	Mon 10/27/2003 2:09 AM
> To:	PostGIS Users Discussion
> Cc:
> Subject:	Re: [postgis-users] Suspect shape(s) -- multipolygons and
> large loadfiles
> What version of shp2pgsql are you using ?
> There have been changes in the loader, try latest CVS
> and see what happens.
> --strk
> gsw wrote:
>> Dear peoples,
>> I've got to move several dozen tables of varying size (a few hundred
>> to about 500,000 rows per table) of spatial data from Informix'
>> spatial blade into postgres postgis. The data is well-behaved by
>> Informix' standards. I unload using the unloadshp Informix utility
>> which gives me shape files; I then process those with the postgres'
>> shp2psql utility and then run the resulting sql file.
>> In one file I process some 63097 records and then I get an error:
>> psql:sid_content.sql:63353: ERROR:  couldnt parse objects in GEOMETRY
>> The offending WKT is attached. I did a bit of cut-and-paste and tried
>> it in the JUMP platform and I get a warning (?) in the status bar of
>> that tool saying "Ring Self-Intersection" ... the shape seemed to be
>> functional enough that this tool could display it.
>> So a couple of questions come to mind:
>> a) what might be done about this ? (its a shape of an image file so
>> there may limits in editing it but perhaps tweaks could be made).
>> b) to find this offending record was tedious -- i ended up running
>> the sql file with a "psql -s -f sid_content.sql" option and stepping
>> through the 63k records. Any suggestions for a more painless method
>> of finding offending records would be welcome. Although some largish
>> tables have loaded without error, others have not.
>> Thanks for any advice !
>> Greg Williamson
>> DBA
>> GlobeXplorer LLC
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> <a_big_poly.txt>_______________________________________________
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
