[postgis-users] database backup?
Benjamin Wragg bwragg at tpg.com.au
Tue Oct 28 16:11:13 PST 2003
I think the object creation errors are relating to trying to create some
of the PostGIS objects and functions which are already there. So I don't
think you have to worry, but if I was you I'd do some checking to be
sure.
Cheers,
Benjamin Wragg
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Christoph Spoerri
Sent: Wednesday, 29 October 2003 8:39 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] database backup?
This approach seems to work fine and gives me a working database. Yet,
during
the import process (psql ...), I receive multiple errors mainly
something
like 'psql:<stdin>:261037: invalid command \N'. And in the dump file the
line
251037 is just '.\'. Any idea what this is or does?
I also get quite a few object creation errors (mainly related to plpsql
and
postgis objects), yet I assume that I can ignore them. Correct?
Thanks for helping to clear these issues,
Christoph
On Friday 24 October 2003 10:11 am, Heitzso wrote:
> Not saying it is the correct way to do it, but my nightly backup
> script line is:  /usr/local/pgsql/bin/pg_dump gis | bzip2 >
> /home/backups/gis.sql.bz2
> Then I restore by following postgis rules for initializing postgis db
> then simple run of the dumped file, i.e. psql [options] <
> uncompressed.sql
> I'll be curious to see critiques of my kludge.
> >Hi,
> >I'm looking into backing up the postgis database with pg_dump and
> >restoring it with pg_restore. While pg_dump seems to work without any
> >problems, pg_restore is not able to restore the dump file. No matter
> >how  I set my restore options (oid order, etc.), the template
> >database is use  (template0 or template1), or if I create the postgis
> >objects in advance  or not, I always get an Error of missint
> >relations or existing functions  (e.g. plpsql_call_handler() ).
> >I was wondering what solutions/methods some of the list members use
> >to  backup their database(s).
> >thanks in advance,
> >Christoph
> postgis-users mailing list postgis-users at postgis.refractions.net
