[postgis-users] How do I obtain 2 ids between a pipe segment?
Obe, Regina DND\MIS robe.dnd at ci.boston.ma.us
Fri Apr 2 08:03:41 PST 2004
The way your query is written only the manholes with bounding box with 100
will be considered.  Perhaps that is too small of a bounding box
Have you tried increasing the bounding box.  The fact that your limit 2 is
there will yield the 2 closest.
SELECT manID as manhole,
       distance(geom,'POINT(12433.19 2354.126)'::geometry) as distance
FROM man_hole
WHERE geom && expand('POINT(12433.19 2354.126)'::geometry,500)
ORDER BY distance limit 2
-----Original Message-----
Sent: Friday, April 02, 2004 10:56 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] How do I obtain 2 ids between a pipe segment?
The code, below, performs a radius search for a manhole id but instead of
returning the closest manhole id, we would like it to return at least 2
manhole
ids.
For instance, if there is a repair that occurs on a pipe segment, and
the pipe happens to be between 2 manhole ids ( one manhole id on either side
of
the pipe), we would like to see the 2 manhole ids returned.
Example: KG2354  --------------|---------------- KG2355
Per above example, assume that a repair was done on the center of
the pipe, and there are 2 manhole ids on either side.One called KG2354 is on
the
left of the pipe and another called KG2355 is on the right, we would love to
display those 2 manhole ids.
So far, only the closest to the point of repair is returned.
Can you please tell me what I may have overlooked on the code below?
Thanks in advance.
FROM man_hole
WHERE geom && expand('POINT(12433.19 2354.126)'::geometry,100)
_________________________________________________________________
Get rid of annoying pop-up ads with the new MSN Toolbar - FREE!
http://toolbar.msn.com/go/onm00200414ave/direct/01/
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
