[postgis-users] mlinefromtext problem
strk strk at keybit.net
Wed Apr 7 03:27:20 PDT 2004
On Wed, Apr 07, 2004 at 11:21:55AM +0200, Stefan Donath wrote:
> hi,
> there is a problem occuring while trying to use mlinefromtext:
> this is my sql-command:
> INSERT INTO owt_staatsgrenze_sub (grenzen_id,id,the_geom,test)
>             VALUES (470,44,
>             mlinefromtext('multilinestring((5589287.1 4570062.5,5589288.0
> 4570069.0),
>                                                        (5589288.0
> 4570069.0,5589260.0 4570050.9))'
>                                                        ,20002),
>             'test');
> the error message is:  couldnt parse objects in GEOMETRY
> what's wrong? thanks for help, stefan.
The numbers enclosed in the inner parens are rings. Must have at least
3 points (yours have 2) and the last one must be the same of the first
one.
--strk;
> NEU : GMX Internet.FreeDSL
> Ab sofort DSL-Tarif ohne Grundgebühr: http://www.gmx.net/info
> postgis-users mailing list
