[postgis-users] problem with pgsql2shp and shp2pgsql
strk strk at keybit.net
Wed Apr 7 06:09:14 PDT 2004
On Wed, Apr 07, 2004 at 05:49:42AM -0700, Andrea Rossi wrote:
> When I use the command pgsql2shp I recive the error:
> Initializing... Could not create dbf file
You probably do not have permissions to write the output file.
> and when I try tu use the command shp2pgsql i recive
> the error:
> shape is null
shp2pgsql could not open the shapefile (pretty cryptic message indeed)
> I am logged in as root and I have alla privileges. The
> shap is not null.
> What could be? Any Idea?
You might be using the wrong path... or you found a bug.
What version of pgsql2shp/shp2pgsql are you using ?
What OS are you on ?
--strk;
> __________________________________
> Do you Yahoo!?
> Yahoo! Small Business $15K Web Design Giveaway
> http://promotions.yahoo.com/design_giveaway/
> postgis-users mailing list
