[postgis-users] pgsql2shp errors out after upgrading to 0.8.1
markc at weaponeer.com markc at weaponeer.com
Mon Apr 19 18:55:29 PDT 2004
The -b option caused my particular problem, and seems to
anger the .shp gods in a generic way.  I'll try though to
pass the debug info along tomorrow.  Along with the .shp I
import and try to export again with -b.
Honestly not sure how the -b made it into what we are
doing...  No doubt we randomized ourselves into it!
  Cheers,
  Mark
---- Original message ----
>Date: Mon, 19 Apr 2004 18:36:56 -0700
>From: Paul Ramsey <pramsey at refractions.net>
>Subject: Re: [postgis-users] pgsql2shp errors out after
upgrading to 0.8.1
>To: PostGIS Users Discussion
<postgis-users at postgis.refractions.net>, markc at weaponeer.com
>Mark,
>If you could do the debug routine as strk outlines below
and send him
>the SQL, it will help us kill this bug for future versions.
>Thanks,
>Paul
>strk wrote:
>> On Sun, Apr 18, 2004 at 10:04:57PM -0500,
markc at weaponeer.com wrote:
>> (cuts)
>>>markc at linux:~/qgis-0.1> pgsql2shp -b gis_main
us_plant_rad_x
>>>Initializing... Done.
>>>ERROR:  syntax error at or near ""::text,"" at character
>>>1121
>> You should try to get the entire query.
>> Uncomment around line 312 in pgsql2shp.c and see what is
the query.
>> Note that the -b switch tries to cast every attribute to
a text,
>> except the geometries. Also try without the -b switch.
>> --strk;
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/
postgis-users
>       __
>      | Paul Ramsey
>      | Refractions Research
>      | Email: pramsey at refractions.net
>      | Phone: (250) 885-0632
>      \_
