[postgis-users] length_spheroid problem
Wood Brent pcreso at pcreso.com
Tue Apr 27 23:34:10 PDT 2004
I have a SQL I'm trying to get to return the great circle distance (geographic
distance) between two points. The points are stored as a LINESTRING in the
table the_geom.
The SQL is:
select length_spheroid(the_geom,'SPHEROID["WGS84",6378137,298.25728]') from
but it generates the error message:
ERROR:  SPHEROID parser - couldnt parse the spheroid
I've tried various formats of WGS84, such as WGS_1984 which is used in srtext,
but get the same error & can't tell from the message exactly what is wrong with
my syntax. Any pointers please??
Running PostGIS v.81, Postgres v7.4.2 with proj v4.4.7...
Thanks,
  Brent Wood.
