[postgis-users] about XML
Maurizio Napolitano napo at itc.it
Tue Aug 3 07:20:07 PDT 2004
PINKTOMATE ha scritto:
> Hi and thanks for the possible answer
> OK, when I use the pgsql2shp I create a new shape generated by a
> previous query inside database...GREAT!!!, but the question is: How I
> can convert this shapefile in a XML code for insertion in another code
> quickly, somebody knows the trick??? regards
A XML implementation for the GIS data is GML (Geographic Markup Language).
With ogr2ogr you can change from a GIS format to another, so
you can transform your ESRI shape file (or PostGIS table) into
a GML (so a XML) file
