[postgis-users] Need some help
strk strk at keybit.net
Thu Aug 5 11:19:14 PDT 2004
On Thu, Aug 05, 2004 at 10:48:37AM -0700, David Blasby wrote:
> strk,
> You might want to add constructors to postgis.  The SF SQL manual
> recommends some.
> Some of the obvious ones, from the user's perspective, are:
> MULTIPOINT->LINESTRING
> MULTILINESTRING->POLYGON
> (x,y[,z]) -> POINT
> you can use collect_geom(g1,g2) to build a multipoint out of single
> points and multilinestrings out of linestrings.
> dave
It would be nice to have.
Probably Paul prefers to have new features implemented on LWGEOM, though.
(well done again Dave!).
--strk;
> On Thu, 5 Aug 2004 19:14:31 +0200, strk <strk at keybit.net> wrote:
> > On Thu, Aug 05, 2004 at 11:09:44AM -0600, Zamil Murji wrote:
> > > I'm open to using pl/pgsql...any sample code to do it with that?
> > If you give it a try and report your code, I'm open to review it.
> > Basically you'll need to construct a WKT representation of the
> > line you need... see postgis manual on how to extract X/Y values
> > from your points.
> > --strk;
> > > Thanks
> > > Zamil
> > > -----Original Message-----
> > > From: postgis-users-bounces at postgis.refractions.net
> > > [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of strk
> > > Sent: Thursday, August 05, 2004 11:01 AM
> > > To: PostGIS Users Discussion
> > > Subject: Re: [postgis-users] Need some help
> > > On Thu, Aug 05, 2004 at 10:53:06AM -0600, Zamil Murji wrote:
> > > > Hello list,
> > > > I have a column in a table defined as a LINESTRING, the lines display just fine using mapserver. Now I want to create a line that is perpendicular to that line, but I want to do it with SQL. I can get the end point of the line, but I'm at a loss of what to do next. My goal is to create a T with the line that is already stored in the db. What is the quickest way to do something like this.
> > > > Thanks in advance,
> > > > Zamil
> > > Postgis does not currently support creating geometries with SQL.
> > > You need pl/pgsql for that.
> > > --strk;
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
