[postgis-users] Re: GEOS install help for Solaris 9
strk strk at keybit.net
Sun Aug 8 11:22:05 PDT 2004
On Sun, Aug 08, 2004 at 10:35:10AM -0700, Matthew Perry wrote:
> Hello all,
>   I ran XMLTester to confirm that the GEOS libraries
> are functioning. All 490 tests passed, 0 failed. So am
> I correct in assuming that GEOS was installed
> properly?
> If GEOS is installed correctly, why can't postgis
> access the GEOS functions?
It seems it can. And it faults....
> - libgeos.so is in /usr/local/lib/
> - Our postgis makefile has the following lines:
>    USE_GEOS=1
>    ifeq (${GEOS_DIR},)
>         GEOS_DIR=/usr/local
>    endif
> - All the other non-geos postgis functions are working
> properly.
> I am out of ideas! Does anyone have any suggestions
> about what we should check next??
If you have valgrind and a bourne shell you can try this:
$ valgrind postgres <<EOF > out 2>&1
SELECT intersection(POINT(1 1), POINT(1 1));
EOF
Then check (and send) the produced 'out' file.
--strk;
> Thanks,
> Matthew Perry
> Humboldt State University
> Environmental and Natural Resource Sciences
> Paul Ramsey wrote:
> >Start with the XMLTester, that exercises things a bit
> >more.
> > Hello,
> >   We are trying to run postgis on Solaris 9.
> > Everything is ok except for the GEOS functions.
> > For example, check out the following output from
> > psql...
> > test=# select intersection('POINT(1 1)', 'POINT(1
> > 1)');
> > server closed the connection unexpectedly
> >         This probably means the server terminated
> > abnormally
> >         before or while processing the request.
> > The connection to the server was lost. Attempting
> > reset: Failed.
> > !> select * from pg_tables;
> > You are currently not connected to a database.
> > The logfile provides the following:
> > LOG:  server process (PID 19666) was terminated by
> > signal 11
> > LOG:  terminating any other active server processes
> > LOG:  all server processes terminated;
> reinitializing
> > LOG:  database system was interrupted at 2004-08-05
> > 13:55:59 PDT
> > LOG:  checkpoint record is at 0/C75FA8
> > LOG:  redo record is at 0/C75FA8; undo record is at
> > 0/0; shutdown TRUE
> > LOG:  next transaction ID: 558; next OID: 27382
> > LOG:  database system was not properly shut down;
> > automatic recovery in progress
> > FATAL:  the database system is starting up
> > LOG:  invalid magic number 0000 in log file 0,
> segment
> > 0, offset 13066240
> > LOG:  redo is not required
> > LOG:  database system is ready
> > So is it reasonable to assume that GEOS was not
> > installed properly? How would I test this? I noticed
> a
> > little app that comes with GEOS called
> > "SimpleWKTTester" but can't make it do anything, nor
> > can I find any documentation on it.
> > Any ideas? Anyone have any experience with this
> > problem on Solaris before?
> > Thanks for the input,
> > Matthew Perry
> postgis-users mailing list
