[postgis-users] error during postgis.sql command
TECHER Jean David davidtecher at yahoo.fr
Tue Aug 10 07:11:55 PDT 2004
> could not load library "/usr/local/pgsql/
> lib/libpostgis.so.0.8": libproj.so.0: cannot open
> shared object file: No such file or directo
> ry
Do
 find / -name libproj.so.0
You should have libproj.so.0 at /usr/local/lib
As root, just do
	echo /usr/local/lib >> /etc/ld.so.conf
Then
	ldconfig
or if it is not example libproj.so.o is at /fooo_fooo
	do
		echo /fooo_fooo >> /etc/ld.so.conf
	then  ldconfig
Then drop your db
	drop yourdb
	createdb ....
	createlang ....
	psql -d ....
