[postgis-users] other errors during postgis.sql command
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Tue Aug 10 11:14:10 PDT 2004
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Benedetto Porfidia
> Sent: 10 August 2004 17:40
> To: PostGIS Users Discussion
> Subject: [postgis-users] other errors during postgis.sql command
> Hallo All
> I have installed postgis on latest postgres sources with no
> errors and all seem to be gone ok. but when I try the psql
> command i have these similar errors to the
> previous message.
> I tried to drop the db, run ldconfig with the path found with "find
> /-name libpostgis.so.0.8", create a new db,
> run createlang.... ,but i have the same error.
> postgres at bumbum:/home/jodalap$ /usr/local/pgsql/bin/psql -d gis_db -f
> /usr/pg_data/postgis.sql
> BEGIN
>         message
>  PL/PgSQL is installed.
> (1 row)
> psql:/usr/pg_data/postgis.sql:47: NOTICE:  type "histogram2d"
> is not yet
> definedDETAIL:  Creating a shell type definition.
> psql:/usr/pg_data/postgis.sql:47: ERROR:  could not load library
> "/usr/local/pgsql/lib/libpostgis.so.0.8":
> /usr/local/pgsql/lib/libpostgis.so.0.8: undefined symbol:
> pj_get_release
> psql:/usr/pg_data/postgis.sql:52: ERROR:  current transaction is
> aborted, commands ignored until end of transaction block
> .etc etc (the same for all lines) and
> commit
> please, someone can give some help
> thanks
Hi Benedetto,
Looking at the current CVS of PostGIS shows that postgis_transform.c
recently has been changed to use the function pj_get_release() that was
only introduced with version 4.4.8 of PROJ.4. Therefore if you upgrade
to PROJ.4.4.8, then you should find that you can build and use the
current CVS version of PostGIS successfully.
strk, can we detect the version of PROJ.4 by checking PJ_VERSION in
/include/proj_api.h and only include the call to pj_get_release() if we
are >= 448?
Kind regards,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
