[postgis-users] Large (and slow) Intersection
James McEachern jamesm at threetier.com
Fri Aug 27 00:20:29 PDT 2004
Hi All,
We are trying to locate point objects that fall within polygon objects.
Our data points are spread out over a large area, and the polygons used to
locate may be spread over an equally large area, but only would have a very
small coverage (< 1% of total area)
There are ~500K point objects, and upwards of 1000 polygons.
Of course if we union the polygons together, the resulting
envelope used for the && operation basically gets all of the points.
And this would run for ever.
By doing the query on any single polygon with the && and intersection,
we get the correct result very fast, therefore running it for
1000 polygons, it would take around ~1000 seconds. Quite manageable.
I have seen previous posts regarding this problem/solution, and they used an
iterative solution, to walk over the polygon result set (in code)
doing each && intersection independently and summing (actually unioning)
the results. Creating a stored proc looks like one solution.
I am looking for a correlated sub-query (or something)
to get the result.
Does anyone know if a single (correlated) query is possible?
Thanks,
James S McEachern
Geo Webworks Inc.
2020, 801 6 Avenue SW
Calgary, Alberta
T2P 3W2
403-301-4001
