[postgis-users] trying to make
János janos.lobb at yale.edu
Wed Dec 8 12:50:58 PST 2004
Well, I had clean totally the Postgresql source - with a fresh tar -
and now I am able to install PostGis.  I also gave up on at this moment
the ssl option for Postgres.  It would be good if the INSTALL would
tell where it is on different platforms.  In OSX it is definitely NOT
in /usr/local, although in Darwin it is.
Thanks again,
János
On Dec 3, 2004, at 5:31 AM, strk at refractions.net wrote:
> On Thu, Dec 02, 2004 at 11:33:01AM -0500, János wrote:
>> Today I came back to this compile and tried your suggestion.  Here is
>> the result:
>> Janos:/Volumes/Data/Downloads/postgresql-7.4.6/contrib/postgis-0.9.0
>> janos$ sudo make CFLAGS="-lssl"
>> ./geos_version.sh /usr/local > postgis_geos_version.h
>> make -C loader
>> gcc -no-cpp-precomp -g -I.. -I. -I../../../src/interfaces/libpq -lssl
>> -DFRONTEND -DSYSCONFDIR='"/Volumes/Apps/pgsql/etc"' -DUSE_VERSION=73
>> shpopen.o dbfopen.o getopt.o pgsql2shp.o
>> -L../../../src/interfaces/libpq -lpq -L../../../src/port -lstdc++   -o
>> pgsql2shp
>> ld: ../../../src/interfaces/libpq/libpq.a(fe-secure.o) illegal
>> reference to symbol: _BIO_free defined in indirectly referenced
>> dynamic
>> library /usr/lib/libcrypto.0.9.7.dylib
>> make[1]: *** [pgsql2shp] Error 1
>> make: *** [loaderdumper] Error 2
>> Looks like I still reference wrongly the openssl libraries when I
>> compile postgresql.  My next try will be to have just the --prefix for
>> the config of postgresql and nothing else.
>> What do you think ?
> Sure, try that.
> Anyway, I think pgsql/ssl-postgis case must be handled somehow,
> I just dunno how (never built ssl support in).
> --strk;
>> Thanks ahead,
>> János
>> On Nov 22, 2004, at 4:35 PM, strk at refractions.net wrote:
>>> make CFLAGS="-lssl"
>> Trying to argue with a politician is like lifting up the head of a
>> corpse.
>> (S. Lem: His Master Voice)
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
We plan to reset the system twice tomorrow which improves performance
until the problem reoccurs.
--ITS Communication
