[postgis-users] something strange when I was testing the instalation.
strk at refractions.net strk at refractions.net
Mon Dec 13 10:39:01 PST 2004
On Mon, Dec 13, 2004 at 10:13:10AM -0800, Michael Jenik wrote:
> Hiii ,
> I have installes postgresql and then postgis.
> Everything form .deb packages. Note that im using a
> debian sistem.
> so when i tried the sql file that comes whit the
> postgis i found some wired things.
> It is in spanish but it means something like
> "histogram2d not defined"
> "creating uncomplete definition of type.."
Is just a NOTICE, nothing to be worried about.
It's because type constructors refer to the type
which is defined later (which requires them to
be defined).
--strk;
> here is what i saw:
> # psql -f postgis.sql -d mydata
> BEGIN
>         message
>  PL/PgSQL is installed.
> (1 row)
> psql:postgis.sql:38: NOTICE:  el tipo "histogram2d" no
> ha sido definido a?n
> DETAIL:  Creando una definici?n de tipo inconclusa.
> CREATE FUNCTION
> psql:postgis.sql:43: NOTICE:  el tipo de argumento
> histogram2d est? inconcluso
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis.sql:59: NOTICE:  el tipo "box3d" no ha
> sido definido a?n
> CREATE FUNCTION
> psql:postgis.sql:64: NOTICE:  el tipo de argumento
> box3d est? inconcluso
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis.sql:79: NOTICE:  el tipo "spheroid" no ha
> sido definido a?n
> CREATE FUNCTION
> psql:postgis.sql:84: NOTICE:  el tipo de argumento
> spheroid est? inconcluso
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis.sql:99: NOTICE:  el tipo "wkb" no ha sido
> definido a?n
> CREATE FUNCTION
> psql:postgis.sql:104: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:109: NOTICE:  el tipo de retorno wkb
> est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:118: NOTICE:  el tipo "chip" no ha
> sido definido a?n
> CREATE FUNCTION
> psql:postgis.sql:123: NOTICE:  el tipo de argumento
> chip est? inconcluso
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis.sql:139: NOTICE:  el tipo "geometry" no
> CREATE FUNCTION
> psql:postgis.sql:144: NOTICE:  el tipo de argumento
> geometry est? inconcluso
> CREATE FUNCTION
> CREATE TYPE
> CREATE FUNCTION
> psql:postgis.sql:179: NOTICE:  CREATE TABLE / PRIMARY
> KEY crear? el ?ndice impl?cito "spatial_ref_sys_pkey"
> para la tabla "spatial_ref_sys"
> CREATE TABLE
> psql:postgis.sql:201: NOTICE:  CREATE TABLE / PRIMARY
> KEY crear? el ?ndice impl?cito "geometry_columns_pk"
> para la tabla "geometry_columns"
> CREATE TABLE
> UPDATE 1
> UPDATE 1
> UPDATE 1
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> psql:postgis.sql:444: NOTICE:  el tipo de retorno wkb
> est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:449: NOTICE:  el tipo de retorno wkb
> est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:454: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:459: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:464: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:469: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:474: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:479: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:484: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:489: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:495: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:500: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:505: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:510: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:515: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:520: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:526: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:531: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:537: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:542: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:547: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:552: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:558: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:563: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:568: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:573: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:578: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:583: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:590: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> psql:postgis.sql:595: NOTICE:  el tipo de argumento
> wkb est? inconcluso
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE TYPE
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE OPERATOR CLASS
> UPDATE 1
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> COMMIT
> Thank you.
> And sorry for the noise,.
> michael
> __________________________________
> Do you Yahoo!?
> Yahoo! Mail - Find what you need with new enhanced search.
> http://info.mail.yahoo.com/mail_250
> postgis-users mailing list
