[postgis-users] problem occured when installing postgis,help me
strk at refractions.net strk at refractions.net
Tue Dec 28 23:49:02 PST 2004
On Wed, Dec 29, 2004 at 12:22:49PM +0800, boo hou wrote:
> The problem occured at the moment when i execute #psql
> -d mydb -f /usr/local/pgsql/share/postgis/sql, the
> transactions were aborted. Then i   resort the errors
> into a file to trace the reason. What i got is as
> follows. It's sure pl/pgsql is installed. So what's
> wrong with it? Please help me. Thanx in advance!
It's not finding libgeos.so.2
If you DID install GEOS run ldconfig.
If you DID NOT install GOES set USE_GEOS=1
in Makefile.config.
--strk;
> BEGIN
>         message
>  PL/PgSQL is installed.
> (1 row)
> COMMIT
> psql:postgis.sql:47: NOTICE:  type "histogram2d" is
> not yet defined
> DETAIL:  Creating a shell type definition.
> psql:postgis.sql:47: ERROR:  could not load library
> "/usr/local/pgsql/lib/libpostgis.so.0.9":
> libgeos.so.2: cannot open shared object file: No such
> file or directory
> psql:postgis.sql:52: ERROR:  current transaction is
> aborted, commands ignored until end of transaction
> block
> psql:postgis.sql:60: ERROR:  current transaction is
> block
> psql:postgis.sql:77: ERROR:  current transaction is
> block
> psql:postgis.sql:82: ERROR:  current transaction is
> block
> psql:postgis.sql:89: ERROR:  current transaction is
> block
> psql:postgis.sql:106: ERROR:  current transaction is
> block
> psql:postgis.sql:111: ERROR:  current transaction is
> block
> psql:postgis.sql:118: ERROR:  current transaction is
> block
> psql:postgis.sql:135: ERROR:  current transaction is
> block
> psql:postgis.sql:140: ERROR:  current transaction is
> block
> psql:postgis.sql:146: ERROR:  current transaction is
> block
> psql:postgis.sql:151: ERROR:  current transaction is
> block
> psql:postgis.sql:163: ERROR:  current transaction is
> block
> psql:postgis.sql:180: ERROR:  current transaction is
> block
> psql:postgis.sql:185: ERROR:  current transaction is
> block
> psql:postgis.sql:193: ERROR:  current transaction is
> block
> psql:postgis.sql:210: ERROR:  current transaction is
> block
> psql:postgis.sql:215: ERROR:  current transaction is
> block
> psql:postgis.sql:233: ERROR:  current transaction is
> block
> psql:postgis.sql:260: ERROR:  current transaction is
> block
> psql:postgis.sql:271: ERROR:  current transaction is
> block
> psql:postgis.sql:293: ERROR:  current transaction is
> block
> psql:postgis.sql:301: ERROR:  current transaction is
> block
> psql:postgis.sql:305: ERROR:  current transaction is
> block
> psql:postgis.sql:309: ERROR:  current transaction is
> block
> psql:postgis.sql:313: ERROR:  current transaction is
> block
> psql:postgis.sql:317: ERROR:  current transaction is
> block
> psql:postgis.sql:321: ERROR:  current transaction is
> block
> psql:postgis.sql:325: ERROR:  current transaction is
> block
> psql:postgis.sql:368: ERROR:  current transaction is
> block
> psql:postgis.sql:407: ERROR:  current transaction is
> block
> psql:postgis.sql:414: ERROR:  current transaction is
> block
> psql:postgis.sql:447: ERROR:  current transaction is
> block
> psql:postgis.sql:572: ERROR:  current transaction is
> block
> psql:postgis.sql:685: ERROR:  current transaction is
> block
> psql:postgis.sql:705: ERROR:  current transaction is
> block
> psql:postgis.sql:724: ERROR:  current transaction is
> block
> psql:postgis.sql:747: ERROR:  current transaction is
> block
> psql:postgis.sql:753: ERROR:  current transaction is
> block
> psql:postgis.sql:764: ERROR:  current transaction is
> block
> psql:postgis.sql:769: ERROR:  current transaction is
> block
> psql:postgis.sql:774: ERROR:  current transaction is
> block
> psql:postgis.sql:779: ERROR:  current transaction is
> block
> psql:postgis.sql:784: ERROR:  current transaction is
> block
> psql:postgis.sql:789: ERROR:  current transaction is
> block
> psql:postgis.sql:794: ERROR:  current transaction is
> block
> psql:postgis.sql:799: ERROR:  current transaction is
> block
> psql:postgis.sql:804: ERROR:  current transaction is
> block
> psql:postgis.sql:809: ERROR:  current transaction is
> block
> psql:postgis.sql:814: ERROR:  current transaction is
> block
> psql:postgis.sql:819: ERROR:  current transaction is
> block
> psql:postgis.sql:824: ERROR:  current transaction is
> block
> psql:postgis.sql:829: ERROR:  current transaction is
> block
> psql:postgis.sql:834: ERROR:  current transaction is
> block
> psql:postgis.sql:839: ERROR:  current transaction is
> block
> psql:postgis.sql:848: ERROR:  current transaction is
> block
> psql:postgis.sql:853: ERROR:  current transaction is
> block
> psql:postgis.sql:858: ERROR:  current transaction is
> block
> psql:postgis.sql:863: ERROR:  current transaction is
> block
> psql:postgis.sql:868: ERROR:  current transaction is
> block
> psql:postgis.sql:873: ERROR:  current transaction is
> block
> psql:postgis.sql:878: ERROR:  current transaction is
> block
> psql:postgis.sql:883: ERROR:  current transaction is
> block
> psql:postgis.sql:888: ERROR:  current transaction is
> block
> psql:postgis.sql:893: ERROR:  current transaction is
> block
> psql:postgis.sql:899: ERROR:  current transaction is
> block
> psql:postgis.sql:904: ERROR:  current transaction is
> block
> psql:postgis.sql:909: ERROR:  current transaction is
> block
> psql:postgis.sql:914: ERROR:  current transaction is
> block
> psql:postgis.sql:919: ERROR:  current transaction is
> block
> psql:postgis.sql:924: ERROR:  current transaction is
> block
> psql:postgis.sql:930: ERROR:  current transaction is
> block
> psql:postgis.sql:935: ERROR:  current transaction is
> block
> psql:postgis.sql:941: ERROR:  current transaction is
> block
> psql:postgis.sql:946: ERROR:  current transaction is
> block
> psql:postgis.sql:951: ERROR:  current transaction is
> block
> psql:postgis.sql:956: ERROR:  current transaction is
> block
> psql:postgis.sql:962: ERROR:  current transaction is
> block
> psql:postgis.sql:967: ERROR:  current transaction is
> block
> psql:postgis.sql:972: ERROR:  current transaction is
> block
> psql:postgis.sql:977: ERROR:  current transaction is
> block
> psql:postgis.sql:982: ERROR:  current transaction is
> block
> psql:postgis.sql:987: ERROR:  current transaction is
> block
> psql:postgis.sql:994: ERROR:  current transaction is
> block
> psql:postgis.sql:999: ERROR:  current transaction is
> block
> psql:postgis.sql:1014: ERROR:  current transaction is
> block
> psql:postgis.sql:1019: ERROR:  current transaction is
> block
> psql:postgis.sql:1024: ERROR:  current transaction is
> block
> psql:postgis.sql:1030: ERROR:  current transaction is
> block
> psql:postgis.sql:1035: ERROR:  current transaction is
> block
> psql:postgis.sql:1040: ERROR:  current transaction is
> block
> psql:postgis.sql:1045: ERROR:  current transaction is
> block
> psql:postgis.sql:1050: ERROR:  current transaction is
> block
> psql:postgis.sql:1055: ERROR:  current transaction is
> block
> psql:postgis.sql:1060: ERROR:  current transaction is
> block
> psql:postgis.sql:1065: ERROR:  current transaction is
> block
> psql:postgis.sql:1070: ERROR:  current transaction is
> block
> psql:postgis.sql:1075: ERROR:  current transaction is
> block
> psql:postgis.sql:1080: ERROR:  current transaction is
> block
> psql:postgis.sql:1085: ERROR:  current transaction is
> block
> psql:postgis.sql:1090: ERROR:  current transaction is
> block
> psql:postgis.sql:1095: ERROR:  current transaction is
> block
> psql:postgis.sql:1100: ERROR:  current transaction is
> block
> psql:postgis.sql:1105: ERROR:  current transaction is
> block
> psql:postgis.sql:1110: ERROR:  current transaction is
> block
> psql:postgis.sql:1115: ERROR:  current transaction is
> block
> psql:postgis.sql:1120: ERROR:  current transaction is
> block
> psql:postgis.sql:1125: ERROR:  current transaction is
> block
> psql:postgis.sql:1130: ERROR:  current transaction is
> block
> psql:postgis.sql:1135: ERROR:  current transaction is
> block
> psql:postgis.sql:1141: ERROR:  current transaction is
> block
> psql:postgis.sql:1146: ERROR:  current transaction is
> block
> psql:postgis.sql:1151: ERROR:  current transaction is
> block
> psql:postgis.sql:1156: ERROR:  current transaction is
> block
> psql:postgis.sql:1161: ERROR:  current transaction is
> block
> psql:postgis.sql:1166: ERROR:  current transaction is
> block
> psql:postgis.sql:1171: ERROR:  current transaction is
> block
> psql:postgis.sql:1176: ERROR:  current transaction is
> block
> psql:postgis.sql:1182: ERROR:  current transaction is
> block
> psql:postgis.sql:1187: ERROR:  current transaction is
> block
> psql:postgis.sql:1192: ERROR:  current transaction is
> block
> psql:postgis.sql:1197: ERROR:  current transaction is
> block
> psql:postgis.sql:1202: ERROR:  current transaction is
> block
> psql:postgis.sql:1207: ERROR:  current transaction is
> block
> psql:postgis.sql:1212: ERROR:  current transaction is
> block
> psql:postgis.sql:1217: ERROR:  current transaction is
> block
> psql:postgis.sql:1222: ERROR:  current transaction is
> block
> psql:postgis.sql:1227: ERROR:  current transaction is
> block
> psql:postgis.sql:1233: ERROR:  current transaction is
> block
> psql:postgis.sql:1238: ERROR:  current transaction is
> block
> psql:postgis.sql:1243: ERROR:  current transaction is
> block
> psql:postgis.sql:1248: ERROR:  current transaction is
> block
> psql:postgis.sql:1253: ERROR:  current transaction is
> block
> psql:postgis.sql:1258: ERROR:  current transaction is
> block
> psql:postgis.sql:1263: ERROR:  current transaction is
> block
> psql:postgis.sql:1268: ERROR:  current transaction is
> block
> psql:postgis.sql:1273: ERROR:  current transaction is
> block
> psql:postgis.sql:1278: ERROR:  current transaction is
> block
> psql:postgis.sql:1284: ERROR:  current transaction is
> block
> psql:postgis.sql:1289: ERROR:  current transaction is
> block
> psql:postgis.sql:1295: ERROR:  current transaction is
> block
> psql:postgis.sql:1305: ERROR:  current transaction is
> block
> psql:postgis.sql:1310: ERROR:  current transaction is
> block
> psql:postgis.sql:1315: ERROR:  current transaction is
> block
> psql:postgis.sql:1324: ERROR:  current transaction is
> block
> psql:postgis.sql:1329: ERROR:  current transaction is
> block
> psql:postgis.sql:1334: ERROR:  current transaction is
> block
> psql:postgis.sql:1339: ERROR:  current transaction is
> block
> psql:postgis.sql:1344: ERROR:  current transaction is
> block
> psql:postgis.sql:1349: ERROR:  current transaction is
> block
> psql:postgis.sql:1354: ERROR:  current transaction is
> block
> psql:postgis.sql:1364: ERROR:  current transaction is
> block
> psql:postgis.sql:1369: ERROR:  current transaction is
> block
> psql:postgis.sql:1374: ERROR:  current transaction is
> block
> psql:postgis.sql:1379: ERROR:  current transaction is
> block
> psql:postgis.sql:1384: ERROR:  current transaction is
> block
> psql:postgis.sql:1389: ERROR:  current transaction is
> block
> psql:postgis.sql:1394: ERROR:  current transaction is
> block
> psql:postgis.sql:1404: ERROR:  current transaction is
> block
> psql:postgis.sql:1409: ERROR:  current transaction is
> block
> psql:postgis.sql:1414: ERROR:  current transaction is
> block
> psql:postgis.sql:1419: ERROR:  current transaction is
> block
> psql:postgis.sql:1424: ERROR:  current transaction is
> block
> psql:postgis.sql:1429: ERROR:  current transaction is
> block
> psql:postgis.sql:1434: ERROR:  current transaction is
> block
> psql:postgis.sql:1443: ERROR:  current transaction is
> block
> psql:postgis.sql:1448: ERROR:  current transaction is
> block
> psql:postgis.sql:1454: ERROR:  current transaction is
> block
> psql:postgis.sql:1459: ERROR:  current transaction is
> block
> psql:postgis.sql:1465: ERROR:  current transaction is
> block
> psql:postgis.sql:1470: ERROR:  current transaction is
> block
> psql:postgis.sql:1477: ERROR:  current transaction is
> block
> psql:postgis.sql:1487: ERROR:  current transaction is
> block
> psql:postgis.sql:1492: ERROR:  current transaction is
> block
> psql:postgis.sql:1497: ERROR:  current transaction is
> block
> psql:postgis.sql:1502: ERROR:  current transaction is
> block
> psql:postgis.sql:1507: ERROR:  current transaction is
> block
> psql:postgis.sql:1512: ERROR:  current transaction is
> block
> psql:postgis.sql:1517: ERROR:  current transaction is
> block
> psql:postgis.sql:1522: ERROR:  current transaction is
> block
> psql:postgis.sql:1531: ERROR:  current transaction is
> block
> psql:postgis.sql:1536: ERROR:  current transaction is
> block
> psql:postgis.sql:1541: ERROR:  current transaction is
> block
> psql:postgis.sql:1546: ERROR:  current transaction is
> block
> psql:postgis.sql:1551: ERROR:  current transaction is
> block
> psql:postgis.sql:1556: ERROR:  current transaction is
> block
> psql:postgis.sql:1565: ERROR:  current transaction is
> block
> psql:postgis.sql:1570: ERROR:  current transaction is
> block
> psql:postgis.sql:1579: ERROR:  current transaction is
> block
> psql:postgis.sql:1589: ERROR:  current transaction is
> block
> psql:postgis.sql:1595: ERROR:  current transaction is
> block
> psql:postgis.sql:1601: ERROR:  current transaction is
> block
> psql:postgis.sql:1607: ERROR:  current transaction is
> block
> psql:postgis.sql:1613: ERROR:  current transaction is
> block
> psql:postgis.sql:1619: ERROR:  current transaction is
> block
> psql:postgis.sql:1625: ERROR:  current transaction is
> block
> psql:postgis.sql:1631: ERROR:  current transaction is
> block
> psql:postgis.sql:1641: ERROR:  current transaction is
> block
> psql:postgis.sql:1647: ERROR:  current transaction is
> block
> psql:postgis.sql:1653: ERROR:  current transaction is
> block
> psql:postgis.sql:1659: ERROR:  current transaction is
> block
> psql:postgis.sql:1664: ERROR:  current transaction is
> block
> psql:postgis.sql:1674: ERROR:  current transaction is
> block
> psql:postgis.sql:1679: ERROR:  current transaction is
> block
> psql:postgis.sql:1684: ERROR:  current transaction is
> block
> psql:postgis.sql:1689: ERROR:  current transaction is
> block
> psql:postgis.sql:1695: ERROR:  current transaction is
> block
> psql:postgis.sql:1700: ERROR:  current transaction is
> block
> psql:postgis.sql:1705: ERROR:  current transaction is
> block
> psql:postgis.sql:1711: ERROR:  current transaction is
> block
> psql:postgis.sql:1717: ERROR:  current transaction is
> block
> psql:postgis.sql:1723: ERROR:  current transaction is
> block
> psql:postgis.sql:1728: ERROR:  current transaction is
> block
> psql:postgis.sql:1735: ERROR:  current transaction is
> block
> psql:postgis.sql:1741: ERROR:  current transaction is
> block
> psql:postgis.sql:1746: ERROR:  current transaction is
> block
> psql:postgis.sql:1751: ERROR:  current transaction is
> block
> psql:postgis.sql:1756: ERROR:  current transaction is
> block
> psql:postgis.sql:1761: ERROR:  current transaction is
> block
> psql:postgis.sql:1766: ERROR:  current transaction is
> block
> psql:postgis.sql:1771: ERROR:  current transaction is
> block
> psql:postgis.sql:1776: ERROR:  current transaction is
> block
> psql:postgis.sql:1781: ERROR:  current transaction is
> block
> psql:postgis.sql:1786: ERROR:  current transaction is
> block
> psql:postgis.sql:1791: ERROR:  current transaction is
> block
> psql:postgis.sql:1801: ERROR:  current transaction is
> block
> psql:postgis.sql:1806: ERROR:  current transaction is
> block
> psql:postgis.sql:1821: ERROR:  current transaction is
> block
> psql:postgis.sql:1826: ERROR:  current transaction is
> block
> psql:postgis.sql:1831: ERROR:  current transaction is
> block
> psql:postgis.sql:1840: ERROR:  current transaction is
> block
> psql:postgis.sql:1849: ERROR:  current transaction is
> block
> psql:postgis.sql:1858: ERROR:  current transaction is
> block
> psql:postgis.sql:1867: ERROR:  current transaction is
> block
> psql:postgis.sql:1876: ERROR:  current transaction is
> block
> psql:postgis.sql:1881: ERROR:  current transaction is
> block
> psql:postgis.sql:1886: ERROR:  current transaction is
> block
> psql:postgis.sql:1910: ERROR:  current transaction is
> block
> psql:postgis.sql:1914: ERROR:  current transaction is
> block
> psql:postgis.sql:1925: ERROR:  current transaction is
> block
> psql:postgis.sql:1938: ERROR:  current transaction is
> block
> psql:postgis.sql:1939: ERROR:  current transaction is
> block
> psql:postgis.sql:1940: ERROR:  current transaction is
> block
> psql:postgis.sql:1941: ERROR:  current transaction is
> block
> psql:postgis.sql:1942: ERROR:  current transaction is
> block
> psql:postgis.sql:1943: ERROR:  current transaction is
> block
> psql:postgis.sql:1944: ERROR:  current transaction is
> block
> psql:postgis.sql:2103: ERROR:  current transaction is
> block
> psql:postgis.sql:2120: ERROR:  current transaction is
> block
> psql:postgis.sql:2137: ERROR:  current transaction is
> block
> psql:postgis.sql:2214: ERROR:  current transaction is
> block
> psql:postgis.sql:2235: ERROR:  current transaction is
> block
> psql:postgis.sql:2256: ERROR:  current transaction is
> block
> psql:postgis.sql:2309: ERROR:  current transaction is
> block
> psql:postgis.sql:2321: ERROR:  current transaction is
> block
> psql:postgis.sql:2334: ERROR:  current transaction is
> block
> psql:postgis.sql:2389: ERROR:  current transaction is
> block
> psql:postgis.sql:2445: ERROR:  current transaction is
> block
> psql:postgis.sql:2459: ERROR:  current transaction is
> block
> psql:postgis.sql:2467: ERROR:  current transaction is
> block
> psql:postgis.sql:2483: ERROR:  current transaction is
> block
> psql:postgis.sql:2492: ERROR:  current transaction is
> block
> psql:postgis.sql:2500: ERROR:  current transaction is
> block
> psql:postgis.sql:2509: ERROR:  current transaction is
> block
> psql:postgis.sql:2514: ERROR:  current transaction is
> block
> psql:postgis.sql:2519: ERROR:  current transaction is
> block
> _________________________________________________________
> Do You Yahoo!?
> 150ÍòÇúMP3·è¿ñËÑ£¬´øÄú´³ÈëÒôÀÖµîÌÃ
> http://music.yisou.com/
> ÃÀÅ®Ã÷ÐÇÓ¦Óо¡ÓУ¬ËѱéÃÀͼ¡¢ÑÞͼºÍ¿áͼ
> http://image.yisou.com
> 1G¾ÍÊÇ1000Õ×£¬ÑÅ»¢µçÓÊ×ÔÖúÀ©ÈÝ£¡
> http://cn.rd.yahoo.com/mail_cn/tag/1g/*http://cn.mail.yahoo.com/event/mail_1g/
> postgis-users mailing list
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
