[postgis-users] Geodetic support, 3D support, arc support.
Kuster Jürgen j.kuster at gmx.at
Thu Feb 12 01:53:35 PST 2004
> > How far are geodetic systems already supported? Is conversion
possible,
> > when shall it be implemented? Do spatial operations work correctly
on
> > this sort of data? Are thus the spatial reference systems of real
use
> > right now?
> As in datum transformations?  or spatial operations, such as area and
> distance calculations?  Note that area and distance calculations are
> not, IIRC, 3D, but much closer to a planar calculation.
Both: Are datum transformations working correctly with current PostGIS
release?
And are spatial operations working correctly regarding the SRS, the
included objects
are assigned to?
Thank you very much,
Juergen Kuster.
