[postgis-users] Distance() vs ? - performance
Tyler Mitchell TMitchell at lignum.com
Tue Feb 17 17:11:13 PST 2004
> This is probably one of those cases where a fuller explanation of your
> problem would help. What are you calculating distances *for*, what are
> your inputs, desired outputs, general description of the problem. It is
> possible that a different approach to your problem could yeild a better
> result.
I thought I had! :)
I've got 54,000 polygons covering an area of 611,000 hectares.  These
polygons represent forest cover types and they are uniquely identified
with a field called link.  The table is called vri_polygons.
I have another table with road linework.  95,000 features spread over the
exact same landbase.  The table is called trim_roads.
What I want to do is calculate the shortest distance from each polygon to
each road.  I want a list of link's and a minium distance to roads.
Here's what I initially did but found performance and memory usage went
gonzo.
CREATE table vri_road_dist as
SELECT vri.link,
min(distance(vri.wkb_geometry,roads.wkb_geometry)::integer) AS
MIN_ROAD_DIST
FROM vri_polygons vri, trim_roads roads
GROUP BY vri.link
I assume this forces a cartesian join and tries to load both intersecting
tables into RAM?  Both tables have GIST indexes.
Tyler
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040217/40d66c56/attachment.html>
