[postgis-users] Distance() vs ? - performance
Ralph Mason ralph.mason at telogis.com
Tue Feb 17 18:43:13 PST 2004
But not to get bitten here - && looks at the bounding box.  So you need
to check the intersection.
foreach forest_poly {
    rowset = select * from roads where road_geom && box(forest_poly
expanded by reasonable search distance)
        and intersects(road_gemo,  forest_poly order expanded by
reasonable search distance ) by distance(road_geom,forest_poly)
        if size(rowset) > 0 then return rowset(0)
        else expand search distance and start again
Ralph.
Paul Ramsey wrote:
> I would suggest doing this with a little external scripting on top of
> the database.  SQL is *not* the optimal language for GIS processing,
> so layering a little logic on top can make a world of difference.
> Finding a minimum distance is already hard, doing for every
> combination is particularly nasty. You will have to tune some magic
> parameters...
> Fire up your perl, or php, or java interpretter (exceptionally pseudo
> code follows):
> expanded by reasonable search distance) order by
> I guarantee this process will return you the results in a much more
> reasonable amount of time. The "reasonable search distance" is the
> magic number. You want it to return "a few" roads in "most" forest
> poly cases, but with an expansion algorithm that doubles it whenever
> you turn up 0 candidates things should be pretty efficient.
> Paul
> Tyler Mitchell wrote:
>>  > This is probably one of those cases where a fuller explanation of
>> your
>>  > problem would help. What are you calculating distances *for*, what
>> are
>>  > your inputs, desired outputs, general description of the problem.
>> It is
>>  > possible that a different approach to your problem could yeild a
>> better
>>  > result.
>> I thought I had! :)
>> I've got 54,000 polygons covering an area of 611,000 hectares.  These
>> polygons represent forest cover types and they are uniquely
>> identified with a field called link.  The table is called vri_polygons.
>> I have another table with road linework.  95,000 features spread over
>> the exact same landbase.  The table is called trim_roads.
>> What I want to do is calculate the shortest distance from each
>> polygon to each road.  I want a list of link's and a minium distance
>> to roads.
>> Here's what I initially did but found performance and memory usage
>> went gonzo.
>> CREATE table vri_road_dist as
>> SELECT vri.link,
>> min(distance(vri.wkb_geometry,roads.wkb_geometry)::integer) AS
>> MIN_ROAD_DIST
>> FROM vri_polygons vri, trim_roads roads
>> GROUP BY vri.link
>> I assume this forces a cartesian join and tries to load both
>> intersecting tables into RAM?  Both tables have GIST indexes.
>> Tyler
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
