[postgis-users] PostGIS Capabilities
Paul Ramsey pramsey at refractions.net
Thu Feb 19 07:15:48 PST 2004
On Thursday, February 19, 2004, at 02:03 AM, Chris Haste wrote:
> Given an irregular closed polygon can we perform SQL statements along
> the lines of "give me all the points that reside within the polygon?
SELECT POINTS FROM MYTABLE WHERE
CONTAINS(GEOMETRYFROMTEXT('POLYGON(..)', SRID), POINTS)
>  Given the same polygon can we obtain all the lines that intersect the
> polygon?
SELECT LINES FROM MYTABLE WHERE NOT
DISJOINT(GEOMETRYFROMTEXT('POLYGON(..)', SRID), LINES)
>  For the above are the coordinates of the intersection points
> calculated and obtainable?
SELECT INTERSECTION(LINES, GEOMETRYFROMTEXT('POLYGON(..)',SRID)) FROM
MYTABLE WHERE NOT DISJOINT(GEOMETRYFROMTEXT('POLYGON(..)', SRID), LINES)
>  Can we obtain all the points within a certain radius of a specified
> points?
SELECT * FROM MYTABLE WHERE
DISTANCE(POINTS,GEOMETRYFROMTEXT('POINT(..)',SRID)) > RADIUS
> Can we obtain all the lines that reside entirely (without intersecting
> the boundary) within a circle or an ellipse?
If you construct the circle or ellipse into a polygon that approximates
the shape, you can use the WITHIN() or CONTAINS() functions for a
strict test of containment.
> Is it possible to specify the segments of a polygon as being either a
> straight line, a rhumb line or a great circle? This is necessary to
> avoid problems to do with the curvature of the earth.
No. You can calculate length_spheroid() directly on the spheroid, but
that is the only geodetic function we have so far.
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
