[postgis-users] PostGIS Capabilities
Jong S. Lee jonglee1 at uiuc.edu
Thu Feb 19 14:43:06 PST 2004
Tyler:
Thanks. It works.  Could you tell me why the following SQL does not working?
SELECT bridge.gid
FROM bridge, highway
WHERE intersects(bridge.the_geom, highway.the_geom) and highway.gid = 49;
For your information, the operation with "intersecting" in ArcGIS worked.
Jong.
Tyler Mitchell wrote:
> Hi Jong,
> > Wow... Amazing PostGIS!!
> That's the spirit!
> > Question:     How to select points on the line?  For example, how to
> > select the bridges on the highway?
> Good practical question - I get excited thinking about just how easy
> this is to do (with no licensing fees involved!).
> I think it will depend on how you define "on the line".  Do the bridge
> share the same point as a node in your line?  Or (as I assume is the
> case) are your points within a certain distance from a line (i.e. < 10
> metres)?
> If the latter, then something like this should do the trick:
> SELECT bridges.name
> FROM bridges, highways
> WHERE DISTANCE(bridges.geometrycolumn, highways.geometrycolumn) < 10;
> There are ways to optimize this query, I just gave you the most basic.
> Hope that helps you out.
> Tyler
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Jong Sung Lee, Graduate Research Assistant
Department of Urban and Regional Planning
University of Illinois at Urbana-Champaign
111 Temple Hoyne Buell Hall
611 East Loredo Taft Dr.
Champaign, IL  61820
Tel:(217)244-6564
E-mail:jonglee1 at uiuc.edu
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040219/4a20efea/attachment.html>
