[postgis-users] Problem with installation
chodgson at refractions.net chodgson at refractions.net
Tue Feb 24 13:09:03 PST 2004
You need to download the source for postgresql, and compile and install it from
that source. Then, untar the postgis source into the contrib directory of the
_postgresql_source_directory_ - this is not /usr/share/pgsql/contrib/!! It
should be something like /usr/local/src/postgresql-7.4.1/
You have probably installed postgresql using an RPM - this is not going to work
with the postgis source install. There are some postgis RPMs available if you
have a compatible version of Linux.
Chris
Quoting Mario Soto Cordones <mario_soto at venezolanadeavaluos.com>:
> postgresql work very good, but now want install postgis but not can
> becose the next error
> [postgis-0.8.1]# make
> >>> Makefile:38: ../../src/Makefile.global: No existe el fichero o el
> >>> directorio
> >>> Makefile:145: /src/Makefile.shlib: No existe el fichero o el directorio
> >>> make: *** No hay ninguna regla para construir el objetivo
> >>> `/src/Makefile.shlib'.  Alto.
> thank you for your help... but no understand what this the error
> Mario Soto
> TECHER Jean David dijo:
> > Hi
> > Did you try to configure postgresql and try make for postgresql before
> > compiling postgis
> > Configure should create the makefile you need
> > TECHER JEAN DAVID
> > - Responsable Informatique 01MAP -
> > e-mail:davidtecher at yahoo.fr
> > Tél: 06 85 37 36 75
> > Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
> > -----Message d'origine-----
> > De : postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net]De la part de
> > Mario Soto Cordones
> > Envoyé : mardi 24 février 2004 20:48
> > À : postgis-users at postgis.refractions.net
> > Objet : Re: [postgis-users] Problem with installation
> > Hi
> > i do this but not work
> > any idea
> > Paul Ramsey dijo:
> >> Yes, please read the installation directions in the README.postgis file
> >> carefully, in particular this sentence:
> >> "To install the module, move this directory to the "contrib" directory
> >> of your
> >> PostgreSQL source installation. "
> >> Paul
> >> On Tuesday, February 24, 2004, at 11:29 AM, Mario Soto Cordones wrote:
> >>> Hi...
> >>> when try to install postgis this say
> >>> directorio
> >>> any idea
> >>> Thank
> >>> Ing. Mario Soto Cordones
> >>>  Venezolana de Avaluos
> >>> www.venezolanadeavaluos.com
> >>> _______________________________________________
> >>> postgis-users mailing list
> >>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>       Paul Ramsey
> >>       Refractions Research
> >>       Email: pramsey at refractions.net
> >>       Phone: (250) 885-0632
