[postgis-users] geos result sets
James S reid james.reid at ed.ac.uk
Wed Feb 25 01:08:50 PST 2004
hi  - thanks and I appreciate that your times at a premium - Ive checked
that the geoms are valid and run the follwing sql (2 tables 1=large
poly,1=small polys (8 polys):
test=# select small.* into temp from small,large where
within(small.the_geom,large.the_geom) = TRUE;
dumping temp gives sthe GEOS result set seen in the screenshot attached
(along with the sql load files for the original shapes).
as you can see - AV gets all eight polys and GEOS only the seven?
Im I missing something or is there a bug?
cheers
james
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, February 24, 2004 5:48 PM
Subject: Re: [postgis-users] geos result sets
> Why dont you send us the actual query thats going wrong?
> ie. something like:
> select within(<polygon 1>,<polygon 2>);
> I need to see what <polygon 1> and <polygon 2> are to do any testing.
> Saying GEOS and ARC have a different answer isnt enough to diagnose a
> problem - I need a specific example.
> I, unfortunately, dont have time to sift through your data in PostGIS
> and ARC to find differences.
> Did you check to see if your geometries are valid (ie. select
> isvalid(the_geom) from <table>;)?
> dave
> postgis-users mailing list
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040225/dcc80eb4/attachment.bin>
