[postgis-users] Install PostGIS 0.8.1...postgis.sql ???
Carlos Fernando Gonçalves cgoncalves at visionweb.com.br
Fri Feb 27 17:31:30 PST 2004
Hello to all.
I am using in my project Linux Red Hat 9, PostgreSQL 7.4.1 (with code
source in tree).
I am making the installation of the version of PostGIS 0.8.1.
The code source where is located the directory of PostGIS is:
/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1
In the file Makefiledo PostGIS, I am with the parameters
USE_PROJ=0,USE_GEOS=0 and USE_STATS=0.
I usually execute,
make
make install
su – postgres
createdb db_test
createlang plpgsql db_test
OK.
I would like to know if it is norm in the moment of execution || psql - d
db_test - f postgis.sql || to appear these messages:
BEGIN
        message
 PL/PgSQL is installed.
(1 row)
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:44:
NOTICE:  type "histogram2d"
is not yet defined
DETAIL:  Creating a shell type definition.
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:49:
NOTICE:  argument type histogram2d is only a shell
CREATE FUNCTION
CREATE TYPE
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:65:
NOTICE:  type "box3d" is not yet defined
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:70:
NOTICE:  argument type box3d is only a shell
CREATE FUNCTION
CREATE TYPE
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:85:
NOTICE:  type "spheroid" is
not yet defined
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:90:
NOTICE:  argument type spheroid is only a shell
CREATE FUNCTION
CREATE TYPE
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:105:
NOTICE:  type "wkb" is not
yet defined
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:110:
NOTICE:  argument type wkb
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:115:
NOTICE:  return type wkb is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:124:
NOTICE:  type "chip" is not yet defined
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:129:
NOTICE:  argument type chip is only a shell
CREATE FUNCTION
CREATE TYPE
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:145:
NOTICE:  type "geometry" is not yet defined
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:150:
NOTICE:  argument type geometry is only a shell
CREATE FUNCTION
CREATE TYPE
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:260:
NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index
"spatial_ref_sys_pkey" for table "spatial_ref_sys"
CREATE TABLE
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:280:
"geometry_columns_pk" for table "geometry_columns"
CREATE TABLE
UPDATE 1
UPDATE 1
UPDATE 1
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:473:
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:478:
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:483:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:488:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:493:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:498:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:503:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:508:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:513:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:518:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:524:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:529:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:534:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:539:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:544:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:549:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:555:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:560:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:566:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:571:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:576:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:581:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:587:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:592:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:597:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:602:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:607:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:612:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:619:
is only a shell
CREATE FUNCTION
psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:624:
is only a shell
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE AGGREGATE
CREATE FUNCTION
CREATE AGGREGATE
CREATE FUNCTION
CREATE AGGREGATE
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE OPERATOR
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE AGGREGATE
CREATE FUNCTION
CREATE AGGREGATE
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE TYPE
CREATE CAST
CREATE CAST
CREATE CAST
CREATE CAST
CREATE CAST
CREATE CAST
CREATE CAST
CREATE CAST
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE OPERATOR CLASS
UPDATE 1
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
COMMIT
Thank you very much
Carlos FG
