[postgis-users] Intersects(geometry,geometry) fails
Paul Ramsey pramsey at refractions.net
Tue Jan 13 15:34:37 PST 2004
What about with postgis-cvs?
David Valentine wrote:
> Same result (on 0.8.1)
> On Jan 13, 2004, at 2:17 PM, Paul Ramsey wrote:
>> Could you try this "reduced" test case on your machine?
>> select intersects(GeometryFromText('POLYGON((2 0,5 0,5 3,2 3,2
>> 0))',54001),'SRID=54001;POLYGON((0 0,2 0,7 5,2 5,0 0))');
>> We found a memory alignment problem on Solaris and fixed it, but it
>> was not in the execution path for this example, so it probably did not
>> fix your problem. Still, try the latest CVS of postgis and see if
>> things have improved.
>> Paul Ramsey wrote:
>>> Well, my compile under Solaris 2.6 did not have any problems, but I
>>> *am* turning up some other issues. Some of the OGC tests cause
>>> segfaults, so we are onto something here.
>>> More l8r.
>>> P.
>>>> On Jan 12, 2004, at 4:17 PM, Paul Ramsey wrote:
>>>>> Werks fer me.
>>>>> What GEOS version? Operating system, compiler?
>>>> solaris8
>>>> both GCC 2.95.3, and 3.3.2 (packages from sunfreeware.com)
>>>> standard solaris tools (/usr/ccs/bin) and GNU binutils
>>>> GCC3.3.2
>>>> Had to use 'CFLAGS=-fPIC' to get postgis-0.80 (and 0.81) to compile
>>>> Under 2.95.3 I could not get geos-1.0 to compile with LDFLAGS=-lstdc++
>>       __
>>      | Paul Ramsey
>>      | Refractions Research
>>      | Email: pramsey at refractions.net
>>      | Phone: (250) 885-0632
>>      \_
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
       __
      | Paul Ramsey
      \_
