[postgis-users] Cross posting: Postgresql 7.4 & cygwin Transactions disabled?
Jody Garnett jgarnett at refractions.net
Thu Jan 15 11:55:58 PST 2004
I have just talked to Dave Blasby - it seems that 7.4 is doing things a
little differently on the database side of things. It seems that we
would have to use an updated jdbc driver - and I am not sure if such a
thing exists yet.
Ideas?
Jody
David Blasby wrote:
>> There has been a bug report that doing transactions with postGIS 0.8
>> and postgresql 7.4 on cygwin does not work.  The error says 'SET
>> AUTOCOMMIT TO OFF is no longer supported'.  I looked into this a bit
>> and it looks like postgresql may have decided to not allow people to
>> turn autocommit off, for some reason like the application should
>> manage resources better or something.  We need to look into it further.
>> Could this possibly be true?
> I belive "SET AUTOCOMMIT = OFF" is no longer supported in 7.4.
> If you havent setup a transaction, your commands will be
> "automagically" surrounded by a 'BEGIN;...COMMIT;' block.
> If you have setup a transaction, you must either COMMIT it or ROLLBACK
> it.
> What do you think this should do:
> SET AUTOCOMMIT = ON;
> BEGIN;
> insert into mytable values (777);
> ROLLBACK;
> If you say '777' should *NOT* be in 'mytable', they you agree with
> postgresql.  If you say it should be in 'mytable', then why do you
> think the database should be ignoring the ROLLBACK command?
> dave
> postgis-users mailing list
