[postgis-users] Installing PostGIS
Robert W. Burgholzer rburgholzer at maptech-inc.com
Thu Jul 29 15:43:14 PDT 2004
Eric,
If it is pre-installed, then I think it is not from source. A download and
source install of Postgresql is not difficult, having done so myself on
Fedora 2, it really requires no extras. I believe it went
configure
make
make install
Good luck,
r.b.
At 03:23 PM 7/29/2004 -0700, you wrote:
>Thanks, i guess the problem is finding the postgresql contrib directory in
>the pre-installed PostgreSQL version that came with Fedora 2?   Anyone
>know where this is or if it exists (I can't find it) ?....otherwise seems
>like i need to re-install PostgreSQL.
>Thanks!
>eric
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net
>[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Robert
>W. Burgholzer
>Sent: Thursday, July 29, 2004 2:41 PM
>To: PostGIS Users Discussion
>Subject: {Spam?} Re: [postgis-users] Installing PostGIS
>Not real experienced myself, but are you un-packing the postgis source
>tree inside /usr/local/psql/contrib/?
>If so, you need to be in the postgresql source directory under contrib.
>This would require that the postgresql be installed from source, or at
>least have a source tree. See:
>http://postgis.refractions.net/docs/c59.html
>Sorry if I am totally off here,
>r.b.
>At 01:08 PM 7/29/2004 -0700, you wrote:
>>Hello,
>>Rookie question.  I'm installing PostGIS (postgis-0.8.2.tar.gz) with the
>>PostgreSQL 7.4.2  on Fedora 2.  I'm getting a "make" error when running
>>/usr/share/pgsql/contib.
>>I've looked at the RPMs but there doesn't seem to be one for PostgreSQL
>>7.4.2.
>>Makefile:38: ../../src/Makefile.global: No such file or directory
>>Makefile:160: /src/Makefile.shlib: No such file or directory
>>make: *** No rule to make target `/src/Makefile.shlib'.  Stop.
>>Any ideas?
>>Thanks,
>>Eric
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>Robert Burgholzer
>Environmental Engineer
>MapTech Inc.
>http://www.maptech-inc.com/
Robert Burgholzer
MapTech Inc.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040729/3d52b11b/attachment.html>
