[postgis-users] How to insert WKB data
Markus Schaber schabios at logi-track.com
Tue Jun 1 09:07:32 PDT 2004
Today, I had some problems inserting Data via WKB format (which we
suspect to be more efficient) into a PostGIS database through JDBC.
We have the data as a byte array, but either
PreparedStatement.setBytes() and .setObject() failed to work.
After some experimentation, I found that I have to encode the byte array
into hex, and then it works (which is ugly because we need to
pre-process the data and double the data size).
For retreiving wkb data, there is a bytea() function that returns the
binary data, but there seems to be no constructor for wkb postgres type
that uses binary data.
It also looks like the PGObject subclassing mechanism only works for
String representations, and the JDBC TypeMap mechanism is not
implemented.
Is there any way that allows efficient storing of WKB data into PostGIS?
Maybe in conjunction with the new lightweight geometries (which I did
not test yet)?
Thanks,
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
