[postgis-users] addgeometrycolumn() does not exist
Romi Hardiyanto rodin at ewesewes.net
Fri Jun 4 19:23:08 PDT 2004
Aaron Steele wrote:
> <snippit>
> CREATE TABLE counties (gid serial, AREA float8, PERIMETER float8,
> CNTY24K97# int4, CNTY24K97- int4, NAME varchar, NAME_CAP varchar, NUM
> int4, FIPS_CODE int4);
You should rename the field "CNTY24K97#" (and maybe CNTY24K97-) in your
cnty24k97.dbf file, before convert cnty24k97.shp again,
or
enclose the CNTY24K97# (and maybe CNTY24K97-) with double quotes in
resulted sql file.
Romi Hardiyanto
