[postgis-users] Error in some reference systems in the table SPATIAL_REF_SYS
strk strk at keybit.net
Mon Jun 14 04:29:15 PDT 2004
On Sat, Jun 12, 2004 at 12:11:19PM -0400, Frank Warmerdam wrote:
> strk wrote:
> >Ciao Gino,
> >I've transformed from-to Gauss-Boaga with no problems using
> >proj4 Rel. 4.4.5 (libproj.so.0.3.1).
> >Did 4.4.8 introduce a stricter projection definition ?
> >Can you provide pointers to the proj4-support-list
> >messages you referred to ?
> Hi,
> There were a number of changes at 4.4.8 release related to support of
> prime meridians.  You would need to ensure you got the latest
> SPATIAL_REF_SYS
> table definitions if you are using PROJ.4.4.8 with PostGIS.  The old
> definitions
> were improperly translated though in some cases the prime meridian were
> compensated for by another bug.
Latest SPATIAL_REF_SYS (1.7) *has* prime meridian specifications (at least
for Gauss-Boaga...) while revision 1.5 *did not* have them.
Prime meridians have been introduced on 2003-02-03.
Should they be removed again to work against proj 4.4.8 ?
--strk;
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> postgis-users mailing list
