[postgis-users] pgsql2shp
Gregory S. Williamson gsw at globexplorer.com
Fri Mar 5 03:30:26 PST 2004
Thanks for the suggestions, but no success.
I am using:
[postgres at content1 globexplorer]$ psql -d gex_runtime -p 5432
gex_runtime=# select postgis_version();
            postgis_version
 0.8 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
I know this will be quite obvious, but in the meantime I think I'll dump it as text and use a perl program to massage that into Informix's spatial format and load that and the use their shape create tool. Seems a little cumbersome though.  ;-}
Greg W.
-----Original Message-----
From:	Heiko Kehlenbrink [mailto:Heiko.Kehlenbrink at vermes.fh-oldenburg.de]
Sent:	Fri 3/5/2004 2:55 AM
To:	postgis-users at postgis.refractions.net
Cc:
Subject:	[postgis-users] pgsql2shp
--- pgsql2shp -f shape_file -g the_geom gex_runtime sid_content_navi
FATAL: database "postgres" does not exist
Did you try this?:
pgsql2shp -f shape_file -p 5432 -u username -P password -g the_geom
Cheers,
Hendrik Aue
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
