[postgis-users] MySQL-PostGIS performance comparison
Paul DuBois paul at kitebird.com
Fri Mar 5 09:33:10 PST 2004
On Fri, Mar 05, 2004 at 09:29:53AM -0800, David Blasby wrote:
> The performance evaluation I did of MySQL's spatial component showed
> that MySQL was either significantly slower in some cases to slightly
> faster in some.
> These differences may have been due to how the disk cache was being used
> (they were run on the same machine).
> If were were to tell me MySQL's non-trasactional tables were 10-20%
> faster than Postgresql's transactional table, I'd believe them.  But, I
> dont believe its 1000% faster!
> It sounds like there's something wrong with your query....
> dave
One possibility might be MySQL's query cache, if any of the test
queries are executed repeatedly.  In this case, the result for a
cached query is returned directly from the cache without having
to be executed at all.  It may be helpful in this case to disable
the cache.
