[postgis-users] && operator memory leak
David Blasby dblasby at refractions.net
Mon Mar 8 10:40:32 PST 2004
Carl Anderson wrote:
> Is anyone actively working on the memory leak in the gist && operator.
> Or can anyone give me a heads up start point?
This is the first report I've got for a memory leak in &&.
I reviewed the code, and there was a very subtle leak in
ggeometry_consistent().  I've fixed it and attached it to this message.
  Give it a try and check to see:
1. you get the same results
2. it doesnt use as much memory
3. it might even be a wee bit faster!
I tested it here, and my query went from 500mb to 64mb.
If it works for you, I'll commit the change.
dave
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040308/be9d958e/attachment.c>
