RES: [postgis-users] Problem during installation
Alex Martins Daher aldaher at cpqd.com.br
Fri Mar 12 11:46:18 PST 2004
Thank you David!
So, I've installed proj and geos libraries, but I am still hitting on
the same error. What else can I verify/do?
[postgres at naja postgis-0.8.1]$ psql -d aldaher -f postgis2.sql
BEGIN
        message
 PL/PgSQL is installed.
(1 row)
psql:postgis2.sql:44: NOTICE:  type "histogram2d" is not yet defined
DETAIL:  Creating a shell type definition.
psql:postgis2.sql:44: ERROR:  could not load library "/l/disk1/postgres/software/source/postgresql-7.4.1/contrib/postgis-0.8.1/libpostgis.so.0.8": /l/disk1/postgres/software/source/postgresql-7.4.1/contrib/postgis-0.8.1/libpostgis.so.0.8: undefined symbol: pj_errno
psql:postgis2.sql:49: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:postgis2.sql:57: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:postgis2.sql:65: ERROR:  current transaction is aborted, commands ignored until end of transaction block
-----Mensagem original-----
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]Em nome de TECHER
Jean David
Enviada em: sexta-feira, 12 de março de 2004 13:00
Para: PostGIS Users Discussion
Assunto: RE: [postgis-users] Problem during installation
Hi Martins
All I knox it is that pj_errno.c  is a file from sources of PROJ.
Perhaps you need to see if you install postgis with PROJ=1.
So Perhaps postgis can't find the PROJ librairies
TECHER JEAN DAVID
- Responsable Informatique 01MAP -
e-mail:davidtecher at yahoo.fr
Tél: 06 85 37 36 75
Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]De la part de Alex
Martins Daher
Envoyé : vendredi 12 mars 2004 15:54
À : postgis-users at postgis.refractions.net
Objet : [postgis-users] Problem during installation
Hi All!
So, I am having a problem during the installation of PostGIS 0.81
in Postgres 7.4.1.
I ran the make/make install, and it was OK, but when I try to load
the spatial types and stuff (inside the postgis.sql), I get the error
below:
[postgres at naja postgis-0.8.1]$ pwd
[postgres at naja postgis-0.8.1]$ psql -d aldaher -f postgis.sql
BEGIN
        message
(1 row)
psql:postgis.sql:44: NOTICE:  type "histogram2d" is not yet defined
psql:postgis.sql:44: ERROR:  could not access file
"$libdir/libpostgis.so.0.8": No such file or directory
psql:postgis.sql:49: ERROR:  current transaction is aborted, commands
psql:postgis.sql:57: ERROR:  current transaction is aborted, commands
psql:postgis.sql:65: ERROR:  current transaction is aborted, commands
psql:postgis.sql:70: ERROR:  current transaction is aborted, commands
psql:postgis.sql:77: ERROR:  current transaction is aborted, commands
Then I replaced the $libdir for the full path, and now I am getting this
one:
BEGIN
        message
(1 row)
bpostgis.so.0.8":
Can anyone help me with this?
Regards,
Alex
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
